500 hp efi ?
Old 06-05-2007 | 05:25 PM
mbones's Avatar
mbones
Default 500 hp efi ?
engine won't idle. give the least bit of fuel and runs fine.
please help.
mbones is offline
Old 06-05-2007 | 05:32 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
IAC Idle Air Controller or idle adjustment
You need to hook it up to a code reader.
Sydwayz is offline
Old 06-05-2007 | 05:40 PM
mbones's Avatar
mbones
on vacation can i take it out and clean
mbones is offline
Old 06-05-2007 | 08:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Its a sensor, and if its bad, its bad.
Temporary fix may be to extend your throttle cable to keep your throttle body/blade open a tad more than usual to get you through vacation, but you really need to hook it up to a scanner. A Merc dealer can help.
If you adjust the idle; do it ONLY enough to keep it running. Make sure your idle is around 750rpm. Any more than that will damage your drive while shifting.
Sydwayz is offline
Old 06-06-2007 | 07:02 AM
Airpacker's Avatar
IAC is a gear driven, reversible linear motor with a pintle valve on the end of it. It is not a "sensor" . It is screwed into the throttle body. It can be removed and replaced with a factory GM unit( which it is anyways). Carbon build up in the throttle bore can cause a no idle condition as well as it supplies a fixed amount of idle air( minimum air rate).
Airpacker is offline
tcm07
10-03-2008 02:00 PM
Elite Marine
20
09-12-2008 05:28 PM
JOJO
8
09-18-2007 01:45 AM
durbin3
3
02-12-2006 03:25 PM
gsmith9898
8
10-20-2005 02:25 PM
