push button start switch, cant find any! >
Old 06-05-2007 | 08:17 PM
Default push button start switch, cant find any!
I'm looking for a pair of those push-button start switches like the viper and s2000 has. I found one from moroso but its really bland black rubber button. Im mounting the key switches in a remote (hidden) location and just putting two big red push-button start switches on the dash. I can't seem to find any though, any help?
waterboy222 is offline
Old 06-05-2007 | 09:01 PM
Steve_H
i spent hours trying to find the same thing without much luck. they were either the industrial type big red buttoms or plain looking black.
ended up going with momentary toggles and added safety covers instead
http://store.summitracing.com/partde...5&autoview=sku
Old 06-05-2007 | 09:08 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Fred at Trick Marine had some at one point.
How are you going to shut the motors off if the keys are hidden?
Remember, when you turn the key on, your hour meters are running up. If you kill the motors somehow, but forget to kill the key switch, you need to make sure you have things wired right.
Sydwayz is offline
hunster's Avatar
Check out your local fast and furious jap car tuner shop. All those kids have them.
hunster is offline
Old 06-05-2007 | 09:14 PM
hmmm.. good call on this one.. never thought about how to turn the motors OFF..
Old 06-05-2007 | 09:40 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You can use the lanyards to turn the engines off, but its not the method I would prefer.
Sydwayz is offline
Old 06-05-2007 | 10:03 PM
even at that, it leaves the hour meters running. I guess Ill have to set up a ignition switch followed by a start switch. With the ignition switch in the off position, it wont run the hour meters, then when id turn it on i could hit the start buttons and fire up.. no?
Ill have so many switches to hit, itll be like firin up an f14!
Old 06-05-2007 | 10:09 PM
Nah, just like a NASCAR (x2)...
Check out www.longacreracing.com
http://www.longacreracing.com/catalo...=1333&catid=13
http://www.longacreracing.com/catalo...=1380&catid=12
Oh yeah, those "Start" buttons that are in most cars these days probably just activate a relay.
handfulz28 is offline
Old 06-05-2007 | 10:17 PM
Ebay is your friend...
http://cgi.ebay.com/GENUINE-S2000-ST...QQcmdZViewItem
How about a remote start kit? Anybody got one of those for their boat? Use an accessory channel to fire up the blowers beforehand...
Old 06-05-2007 | 10:19 PM
im usually in mine when startin it.. cant think of a time id need it started before i got into it.. hahaha..
