removing powerhead on 2.4 merc
I am having trouble removing the powerhead on my merc 2.4 I have undone the 6 bolts the wiring harness cables and shift linkage and can't get it to move i had the lowerunit out about 2 weeks ago and that was simple am i missing something here? are there any tricks?
thanks
josh
thanks
josh
Make sure ALL the bolts are out. I did an 89 Evinrude 225 last winter that would not seperate. I had a lifting ring in the crankshaft and jacked it up a half inch off the floor with a car engine hoist. Whacked the mid with a rubber mallet a few times and it broke loose.
Check screamandfly.com as well for tech tips.
Jim
Jim
there are also 2 more nuts under the the cowling in the very front , just over the pivot pin behind the tilt tube. you will have to loosen them and lift the power head up a little then finish loosening them as there is very little clearance between them and the pivot pin or center section housing.
i believe there are 10 in total.
there are also 2 in the bak under the area behind the coil packs.
good luck.
good luck.
Yep 10 bolts, also the gaskets will stick a lot more than you think. After you reinstall with new gaskets, re-tighten all 10 bolts after the first couple runs and/or a week or two as the gasket will take a set.
handfulz28
Detailing, Painting, & Fiberglass
8
02-22-2008 08:24 AM
littledcsrodshop
06-05-2007 10:04 AM
