CARB help
I was but my crane box died so I went with a MSD box. I still have the crane dist which has vac and rpm adjustments. I noticed a loss in top end power and realized I was running no advance so I went to set up the crane and got the RPM advance worked out but now it runs real rich and stutters. I also noticed my fuel pressure is at 10 psi and drops to 9 psi at wot. With everything locked out it seems to run fine but no top end power.
Thanks for help
Thanks for help
as for the fuel pressure, it should be mor earound 7 psi.
what kind of sock ignition did you have. typicly most conversions use the stock mercruiser, and guys usually use a v-6 module, thunder bolt 4 or 5 h.p ones also work well. they give you a total advance of 34 when timing is set right. then add on the msd for better spark/ ignition.
i myself have done this, but as of late started usind the msd digital 6 plus, as it has numerous timing curves built in. as well as rev limits and inital timing settings.
