Water pressure guage question >
Old 06-12-2007 | 01:32 PM
ls1nova's Avatar
Default Water pressure guage question
So where do you guys put the hose for your water pressure guages? In the block or intake? Is there any difference?
Reason I ask is, I just built a new motor and for the first time I hooked up a guage. I used the 3/8" port right beside the T-stat housing. I'm pegging my 30psi guage at just over 3500 rpm. Engine is 502 mag efi with AFR heads, holley intake, genVI block, hardin marine oil cooler, fuel cooler, and brand new merc water pump. I'm also running a circ pump.
Thanks,
Frank
ls1nova is offline
Old 06-12-2007 | 02:23 PM
tssteph's Avatar
Mine are in the side of the block.
tssteph is offline
Old 06-12-2007 | 03:47 PM
Mine was also connected at the drain on the side of the block.
30psi anywhere in the engine is too much. I think you need a pressure relief kit.
Griff is online now
Old 06-12-2007 | 06:53 PM
monstaaa's Avatar
ditto
monstaaa is offline
Old 06-12-2007 | 06:58 PM
Biggus's Avatar
You need one of these.
Attached Thumbnails Water pressure guage question-mercury-water-pressure-relief-valve.jpg
Biggus is offline
Old 06-12-2007 | 10:13 PM
mines in the block too frank, just gets clogged sometimes.
lilredboat is offline
Old 06-13-2007 | 06:12 AM
East Coast B's Avatar
I hooked in up top like you to avoid the many complaints I heard of it getting clogged when hooking into the drain plugs.
East Coast B is offline
Old 06-13-2007 | 08:45 AM
hoozeyurdaddy's Avatar
where does the pressure releif plumb into???
hoozeyurdaddy is offline
Old 06-13-2007 | 09:27 AM
ls1nova's Avatar
Are your readings any higher than what they were in the block?
ls1nova is offline
dicdik
Do It Yourself, Boating on a Budget
4
07-09-2008 02:28 PM
RedDog382
08-06-2007 09:16 PM
Donzi35ZR
5
09-18-2006 04:16 PM
35 White Lightning
Fountain
6
09-06-2005 01:50 PM
scottsumrall
16
08-20-2002 11:26 PM
