Help! Steering hooked up backwards >
Old 06-13-2007 | 02:12 PM
Unhappy Help! Steering hooked up backwards
Hi,
I have a old 1979 sea ray when you turn right it goes left,
turn left goes right. Can someone tell me how to fix this problem.
Thanks!!
Buns is offline
Old 06-13-2007 | 02:30 PM
Amm
hydraulic or cable steering?
Amm is offline
Old 06-13-2007 | 02:53 PM
cable!
Buns is offline
Old 06-13-2007 | 03:56 PM
Mark's Avatar
Mark is offline
Old 06-13-2007 | 04:00 PM
the cables are wound backwards on the drives under the dash
stevesxm is offline
Old 06-13-2007 | 04:09 PM
Amm
Steering mechanisms don't just reverse themselves. Obviously at some point the steering was installed wrong and someone did not take the time to correct the problem.
You will probably need to assess your situation at the steering box and where the cable connects to the outdrive/outboard.
If your steering looks something like the following you can swap the arm to the other side.
If your steering looks like the following, you may be able to swap the cable so it feeds into the top instead of the bottom, or simply the oppositte of what you have:
Unfortunately, The fact that its wrong now(it wasn't fixed) probably says that there is some reason why this can't be done.
But you should get a good look at your steering mechanism and go from there.
The other option would be to route the cable to the drive from the other side of the boat, if it allows for it.
Amm is offline
Old 06-13-2007 | 04:14 PM
Originally Posted by Buns
Hi,
Thanks!!
Sell it to a dyslexic.
no applause necessary - I'm a consultant.
rbhudelson is offline
Old 06-14-2007 | 09:28 AM
Big Block Billy's Avatar
Post
Probably has ride guide rack, and was installed upside down.
If so, take out center bolt, and unbolt the rack from the helm pull out the pinion by hand and flip the rack , it bolts on from either side so that it can be installed on either side of a boat. This is an easy 5 minute fix. BBB
Big Block Billy is offline
Old 06-14-2007 | 06:53 PM
Thumbs up
Thanks for the help !!!! I'll check it out this weekend.
Buns is offline
Old 06-14-2007 | 07:36 PM
MOP
Sorry guys I did not read all the posts so I may be a bit redundant!!! If it is Teleflex steering the cable must be fed into the bottom hole at the helm the top hole is for the plastic end cover tube.
Phil
MOP is offline
