QIV-X Question >
QIV-X Question
QIV-X Question
Old 06-15-2007 | 01:09 AM
Default QIV-X Question
Hey everyone I have some questions for you. What are all your experiences with the Hydro QIV-X? I have a 27 Advantage with a Teague 800efi. For those of you that don't know, this is a single step hull (very small step) pad bottom boat designed in 1991 (its a little out of date). So far the best speed is 85 at about 5600rpm with a Labbed 26P Bravo I and 1.35 gears. I've run 1.35s and 1.50s and Labbed Bravos and Rev 4s. The Rev 4 was nice but in any type of boat wake or rough water it caused some bad chinewalking. So now I'm looking at maybe checking out a Hydro QIV-X. Anyone tried one on something similar? How does it compare to the Labbed Bravos?
-Tom
ToMorrow44 is offline
Old 06-15-2007 | 01:08 PM
BY U BOY's Avatar
Im running the X on a 21 scarab don't know if i will be much help. The QIV-X will be faster than the bravo on top end but the bravo will give you better cruise i may be wrong. Does your boat have natural bow lift? If so maybe try a QIV which is more of a stern lifting prop.
BY U BOY is offline
Old 06-15-2007 | 03:22 PM
ziemer's Avatar
If you try one, you will most likely need to drop down to a 24 or 25, because the Hydro is a little stiffer than a Bravo.
A 26 Bravo to 26 Hydro QIV-X, the Hydro will be faster at cruise and at top end (if you can spin it). On my straight V, I get between 8% & 10% slip. I also run it on my Allison, and the slip rate drops to around 5%.
ziemer is offline
Old 06-15-2007 | 03:53 PM
BY U BOY's Avatar
I thought the bravo had a better cruise than the Hydro. guess i was wrong. I do like the fact that my slip is only 4% on my scarab.
BY U BOY is offline
Old 06-16-2007 | 12:52 AM
Thanks guys. I've heard that the QIV-X has the same kind of lift characteristics as a Bravo I but is usually a little faster. No this boat does not have much natural bow lift so a stern lifting prop won't work at all. I tried a Hydro P5-X which is supposed to be bowlifting but it picked up the back of the boat big time and ran horribly. Now all I need to do is find someone that has a QIV-X that I can borrow, they seem to be scarce.
-Tom
Old 06-16-2007 | 09:52 AM
BY U BOY's Avatar
Originally Posted by marylandmark
Good info!
I am in the same boat sort of (pardon the pun). I am looking for the same thing you are just in a different size. I have twin outboards, no steps but on the same path as you it sounds like.
I have tried:
27 Mirage +
26 B1
26 B1 labbed
25 QIV-X
24 B1
How did the B1 labbed work for you?
BY U BOY is offline
UNSANE
Prop Talk
0
07-03-2008 10:52 AM
Toffen
Prop Talk
3
01-03-2008 08:25 PM
gofastlvr
Prop Talk
5
08-30-2007 06:11 PM
tekfal23
Prop Talk
6
06-12-2006 12:56 PM
