Cutting Dash - What to use? >
Old 06-16-2007 | 06:56 PM
jayhawk261's Avatar
Default Cutting Dash - What to use?
I need to cut a large hole in my dash to install trim tab indicators. What is the best type of cutting tool? Sawzall? Cutoff wheel? Also, what do other people use to keep the surface gel from getting roughed up? When I installed my new helm and drilled holes, I put down the blue masking tape. When I drilled, I started with small bits and worked up to the correct size hole. Unfortunately the gel at the edges of the holes still chipped a little. What is the best thing to use to keep this from happening.
Also, the cables have "waterproof" fittings through the hull. I assume I should still seal the holes in the transom anyway. Is silicone good enough, or do I need to use a 2 part epoxy?
Thanks!!
jayhawk261 is offline
Old 06-16-2007 | 07:08 PM
If you have the room use a saber saw w/ a fine blade (like for metal) drill holes @ corners first. The urathane calks are better than silicone 3M 5200 is the one of the best .
sschafee01@snet.net is offline
Old 06-16-2007 | 07:16 PM
jayhawk261's Avatar
I don't think space will be a problem. I will have to buy a saw. That isn't a problem either (In my best Homer voice) Mmmmmmmmmmmmmm neeewwwww toooooolsss (drool)!
Can 3M 5200 be purchased at the local Home Depot or Lowes, or is it a marine product?
The indicators came with a template from Stainless Marine with the locations of the starter holes and all. I just don't want to get to violent tearing up the dash with the wrong saw.
Thanks!
Old 06-16-2007 | 10:02 PM
monstaaa's Avatar
i use an air reciprocating saw with a fine blade. and as stated drill the corners. but before you drill with the last bit of final size, use a counter sinc bit then continue drilling. make sure you coat the edges of the new hole with resin as to seal it. and i wouldnt use 5200. if you need to service the fitting or change a cable that stuff is very strong and will make your life difficult. 4200 is not as strong or you can use an adhesive marine silicone.
monstaaa is offline
Old 06-16-2007 | 10:21 PM
jayhawk261's Avatar
Monstaa, do you know anything about the "waterproof fittings"? They came with a bellows that is supposed to silicone and zip tie in place. The K-Plane end of the bellows doesn't seem large enough to go over the plastic cable end that attaches to the K-Plane bolt. Do I jut stretch it good? Also, the cables are 3/16", so I assume a 3/16" hole in the transom would be good enough. I don't want any extra movement space do I?
Old 06-16-2007 | 10:44 PM
monstaaa's Avatar
you should allow for some clearance. not alot but some . for 3/16 drill a 1/4. and see if the cable end is removeable, if not it may be a stretch fit. i know on the outboard style it is.
monstaaa is offline
Old 06-17-2007 | 04:27 AM
Plum_Crazy's Avatar
The best thing I've found for cutting gelcoat is a Dremel with a tile cutting bit.
Plum_Crazy is offline
Old 06-17-2007 | 08:52 AM
monstaaa's Avatar
dremel does work nice, but goes thru bits if the dash is thick say 3/4 .also when the bit wears it snaps and you may scratch the dash.. just be carefull.
monstaaa is offline
Old 06-17-2007 | 09:32 AM
jayhawk261's Avatar
The dash is thick. I would say it is at least 3/4" from when I installed the helm. I think due to the thickness, the jig saw will be the better choice. I think I'm going to get the Craftsman 19.2V cordless with the laser line so I can cut a (somewhat) straight line!
Monstaa, my cables are probably a little on the long side. Should I have any issue with coiling them in a large radius coil under the dash to eat up the excess? The Stainless Marine instructions say they can make a 1" radius bend. I won't give it anything near that.
Old 06-17-2007 | 09:43 AM
zimm17's Avatar
I just did a bunch of big holes in my boat- 3/4" thick dash too. I used a dremel with "roto-zip" bits. They make a roto-zip tool, but the bits work just fine in the dremel tool. Take your time and follow the line on your blue tape.
Use gloves because the dremel will get HOT working that hard.
Seal the raw wood with a little fiberglass resin. I always have west marine resin and hardener with the squirt pumps sitting on the shelf in the garage with some disposable brushes nearby. I use it all the time.
3M 4200 and 5200 is sold at west marine/boat u.s./boater's world. They sell small tubes and large ones too.
zimm17 is offline
