imco drive
Old 06-19-2007 | 08:40 PM
Default imco drive
What is the most obvious way to tell from a regular imco drive from a 2" shorty or is there a diffrence?????
fountainguy214 is offline
Old 06-19-2007 | 09:51 PM
Vinny P's Avatar
I hate the winter!!
If you look at the lower, where it meets the upper, all the way in front on the flat surface, above the bullet, it will say -2.
Vinny P is offline
Old 06-19-2007 | 11:20 PM
Upper half is the same. Lower is significantly shorter and pretty obvious.
Griff is offline
Old 06-20-2007 | 06:39 AM
monstaaa's Avatar
on the minus 2 , the section of the casing above where the prop is is significantly different. as in gone,
monstaaa is offline
Old 06-20-2007 | 12:30 PM
Thank you very much i looked and it said -0 so that means that it is a regular inco ...correct??? thanx for the help
Old 06-20-2007 | 02:09 PM
yep, standard length
Griff is offline
Old 06-20-2007 | 03:27 PM
t500hps's Avatar
21 and 42 footers
ask Docmanrich....
J/K
t500hps is online now
Mr Gadgets
Drives and Lower Units
42
01-18-2008 08:02 AM
plumbers crack
11
04-18-2005 06:52 PM
littleb4
01-01-2003 10:54 PM
bajamag
05-02-2002 09:42 AM
INCOGNITO
03-27-2002 05:38 PM
