7.4 merc running warm
Old 06-19-2007 | 09:16 PM
Default 7.4 merc running warm
I am working on a 1990 Sea Ray with a single fresh water cooled 7.4 merc and bravo drive. I am having an issue with it running warm under a load. The motor will get to about 190*. However, the sea water exiting the heat exchanger is only 105* and the risers are at 115*. I have replaced all bellows and hoses on the outside of the boat, water line from gamble to sea water pump, sea water pump impeller, exhaust manifolds, risers, and thermostat 143*. Flushed and cleaned the heat exchanger. I am clueless as to what could be causing it to run warm. Any advice would be greatly appreciated!
Paul
IHOP is offline
FASTERDAMITT
Wanted
7
06-13-2008 12:42 PM
boathead
11
07-08-2007 06:27 AM
johnnyboatman
9
05-31-2006 09:15 PM
TemptationYachts
1
06-30-2005 09:54 PM
nauticaL ILLUSIONS
07-15-2003 12:31 AM
