running warm to 180 >
running warm to 180
running warm to 180
Old 05-29-2006 | 09:14 PM
johnnyboatman's Avatar
Default running warm to 180
ive got two new 557s w/littlefeild blower, innercoolers, dual dominators, when i go out and run it the temp on one motor goes to 180 and appears to climb higher, if i shut it down and restart it it drop 15degrees instanstly,but come back up there is no thermostat, just a crossover. when idling it flows plenty of water out the exhaust fed by #12 hose and fittings. the pump is different from last year new hoses ,oil coolers but does the same thing as last year water pressure is low to zero at speed but flows fast, checked for stopped up but flows freely. do you think the exhaust it not letting pressure build up or , maybe when someone installed the nose cone they messed up and it is restricted
johnnyboatman is offline
Old 05-30-2006 | 08:21 PM
Default Re: running warm to 180
ttt
Old 05-30-2006 | 10:30 PM
GOODT's Avatar
with out seeing it id guess that it an air lock problem,
these mtrs need stats put 140s in dill 3/16th holes in the circumference and see what happens
GOODT is offline
Old 05-31-2006 | 08:32 PM
There Is No Place For Thermostats
Old 05-31-2006 | 08:34 PM
it seems as someone installed the nose cone maybe wrong? maybe the WATER inlet hole is maybe stopped up, water pressure is low, everthing has been changed on this boat, motors, hoses, coolers, seawater pumps, everthing but the drive. maybe when they plugged the upper holes they closed the water pickup alittle.
Old 05-31-2006 | 08:39 PM
What's the temps in the other motor?
ghittner is offline
Old 05-31-2006 | 08:41 PM
around 150-160
Old 05-31-2006 | 08:43 PM
hte thing is its doin the same thing as last year. the only thing not checked was the drive,
Old 05-31-2006 | 08:47 PM
Did you change the impellers in the raw water pumps?
ghittner is offline
Old 05-31-2006 | 09:15 PM
yes,they are new
boathead
11
07-08-2007 06:27 AM
IHOP
06-19-2007 09:16 PM
RoughKnight
Fountain
1
10-13-2006 06:42 PM
boot
03-16-2003 01:58 PM
