Reading oil level on the stick... >
Old 06-21-2007 | 03:36 PM
Default Reading oil level on the stick...
OK, this will seem like a stupid question but I have to ask. Gen 6 stock pan and stick. When checking the oil with engine at level one side of the stick says full and the other side has notch in it half way between F and L. The side of the stick that says F and L reads full and the other reads half. I understand why this is that way due to the angle of the stick striking the oil level. Think of how when reading a graduated cylinder with liquid you ignore the meniscus in your result. The oil climbs the stick as it would in a beaker more so on the side facing the oil pan bottom.
Which side of the stick did GM intend for us to read? I usually keep it saying half on one side and F on the other.
BadDog is offline
Old 06-21-2007 | 11:58 PM
Read the back, it has always been more accurate for me. Ford, Chev, Pont. Even trannies, read the back....
ghittner is offline
Old 06-22-2007 | 08:03 AM
hoozeyurdaddy's Avatar
It all depends on if you have oil to add as to which way you install the stick, ha-ha. it's probably better to run 1/2 a quart more than less.
hoozeyurdaddy is offline
cloudmaster_321
Do It Yourself, Boating on a Budget
5
08-04-2008 10:42 PM
Rebel_Heart
19
07-08-2006 01:34 AM
speedchangesyou
10
08-29-2005 06:11 PM
FlyFast
13
05-10-2004 11:39 PM
luvlake
6
03-18-2004 10:37 PM
