Help? Bravo 1 Question
Was Running In A Poker Run Saturday Pretty Rough Water In My 32 Active Thunder With 500 Hps And Bravo 1 Drives Was Running About 65 Mph And Felt The Boat Slow Down So I Shut Down And 1 Drive Has No Forward But Reverse Works Fine, If I Shift It In Forward And Try To Spin Prop IT Spins Free No Noises At All, But If I Try To Spin It Backwards When It Should Lock It Does Not And It Gets Tight Then Loose (Clutches Maybe.
Thanks For Any Help
Thanks For Any Help
Raystown is just days away! Tic Toc Tic Toc! Time for the backup drive!!!
All you need is one drive to get you to and from the cove!!!
hehehehehe
Got a number for your groups houseboat yet?
hehehehehe
so to take a look i dont need to pull the drive , just the top cap and if it is that then do you need to pull the drive and tear it down orcan you do it from the cap. nalso is there a 3 bolt plate you can remove and see the shift componets.
thanks
thanks
pulled upper cap and plate with 3 bolts on the back and as far as i can tell everything looks fine all gears shift arm is working no metal filings in oil. is there something i can check mor thorough while im in there. thanks
