Quick question on the safety switch. >
Old 07-01-2007 | 12:27 PM
2112's Avatar
Default Quick question on the safety switch.
I have the accidentally broken the plastic cable connector of the break-away switch on my trailer. It is a Tekonsha 2010. I need to get somewhere before I can replace it. In order to keep the brakes from locking up should I connect the two leads or keep them separate?
2112 is offline
Old 07-02-2007 | 03:37 PM
Did you break the plastic plug /w cable that goes into the switch? If so, you can simply slide something of the appropriate size in there, IE a small wood dowel, BIC pen, etc. You simply want to allow the 2 contacts inside to not touch. I would recommend taping it in place until you can get a replacement pin.
LordAthens is offline
Old 07-04-2007 | 12:28 AM
2112's Avatar
Thanks. I am waiting for a replacement as we speak.
2112 is offline
86formula242ls
08-23-2007 01:14 PM
walzman
08-15-2007 08:27 PM
magnum27
5
07-08-2005 08:16 AM
bripar77
0
01-30-2005 03:06 PM
MAKDADDY
3
06-16-2003 10:19 PM
