Molded Hose From Power Steering Cooler To Bellhousing
anyone have a part # , i just got back form napa and really can't find a hose that has 2 molded 90's to fit..
checked bam's site and can't find any diagrams or part #'s with a bellhousing cooler with a in-line ps cooler on the starboard side...
seems i need about 5" in height and about 7" or so long molded.
i have a box of the hardwall but it will not make those 2 tight bends in such a short distance..
softwall just collapses..
I suggest two hose 90's joined together with a 3" piece of SS tubing with two clamps. Mercury used this rig on long runs on the port side of some engines. These three pieces should allow for a perfect fit...work good, look good.
i actually had luck this afternoon...
went to o'reiliey's and told the counter man , hey , i'm playing water works engineer on a boat and i need something that has 2 90's ,etc... and another piece that has a slight round out...
cat say's , come in the back , i have a wall of hoses...15 minutes of looking ...found what i thought would work....
part# gates 21025 for the rear-- 2 true 90's
part# gates 21171 at the front-- had the right contour
had to cut a few inches off and fit up, the radius on both is not forced at all...
the hose around the engine mount may need a extra piece for rubbing and on the corner of the pan...
had to take a break from those AN fittings...
