Turndown exhaust >
Turndown exhaust
Turndown exhaust
Old 07-06-2007 | 04:13 PM
Dude! Sweet!'s Avatar
Default Turndown exhaust
I did a search and didn't find anything useful.
Anyone using the Gibson or CMI turndowns (aka "DonkeyD1cks") and willing to share their experiences with them? I don't really dig the looks but I've got a couple of young children and the noise at idle and low speed seems to be excessive for them with my current exhaust (which I actually quite enjoy!).
Thanks!
Dude! Sweet! is offline
Old 07-06-2007 | 04:33 PM
Too Old's Avatar
Check with forum members "GLH" or "Old School".
Both of them have some time on sets I've sold them.
Fred
Too Old is offline
Old 07-06-2007 | 04:41 PM
Thanks Fred. Will do.
Old 07-06-2007 | 10:23 PM
Elite Marine's Avatar
We sell alot of them. I run them on my Pantera and Brad runs them on his MTI - see this months Extreme Boat!!!
They work great, are silent when idling and are open pipes when running.
If we can quote you a set, let me know. Pantera discount in effect!
The CMI Sound Elimination Mufflers are awesome also!!
Kirk
Attached Thumbnails Turndown exhaust-custom-downtube2oso.jpg   Turndown exhaust-custom-downtubeoso1.jpg
Elite Marine is offline
Old 07-06-2007 | 10:59 PM
DS, For a slight reduction you can move the allen screw down one more hole on the Shotguns. It will help a little.
Griff is offline
Old 07-07-2007 | 07:58 AM
RMPRam's Avatar
I had air activated mufflers on my 38 Cigarette w/1100's for several years and got nothing but a giant hassle from the water patrol.
I removed them and made a complete new exhaust from the transom. It goes underwater 6" at idle, shoots the exhaust down rather than back and at speed is all between the drives, which helps the noise factor from the side. It is now very quiet. I did drill a small hole in the bottom of ea. pipe, near the transom to relieve the pressure for start-up.
I wish that I would have thought of this years ago, it would have saved me a lot of money for noise tickets and mufflers.
Attached Thumbnails Turndown exhaust-38-cigarette-2006-005.jpg   Turndown exhaust-38-cigarette-2006-007.jpg
RMPRam is offline
Old 07-07-2007 | 08:06 AM
Payton's Avatar
Charter Member #927
RMPRam, that looks very trick. I think it's cool.
Payton is offline
Old 07-07-2007 | 05:14 PM
CcanDo's Avatar
RMPRam, That is a fancy transom.
Subject to engine size, is there most back pressure on the outside banks ? The outside pipes are longer and have two elbows vs. one on the inside. One could wonder if there would be on imbalance.
Have you compared spark plug color and condition between the Port and Starboard heads ? Or, looked at each head with a temperature gun after a hard run ?
CcanDo is offline
Old 07-08-2007 | 08:38 AM
RMPRam's Avatar
I have not done any checks on the outside plugs. I realize that the outer pipes are longer and contain one more sweeping right angle bend than the inner pipes but that was necessary to place the pipes between the drives. I'm running EGT probes on #6 cyl of both motors. That would place one probe on an outer bank,(stbd. motor), and the other on the inner bank. The result that I've seen, is the stbd. motor runs @ 1300 degrees @ speed and the port will run @ 1350. Does not seem to be any problem, so far.
RMPRam is offline
Old 07-08-2007 | 09:53 AM
Thanks for all the info! Next step is to see if they'll actually fit on my boat (it looks like there's a potential interference with steering rams).
