Where to mount gps antenna?
Old 07-06-2007 | 08:11 PM
Tony Montana's Avatar
The BAD Guy
Default Where to mount gps antenna?
I have a Kenwood dvd/gps radio in my F-250. I just bought the Garmin gps box to complete system. Any way my question is where to install the gps antenna? It recommends the roof as the best place. Now I am just crazy enough to drill through my roof ,install a groment w/silicone and be done with it. However the sain part of me says see what my oso brothers think first. I also thought of running the wire through the firewall and putting antenna on hood?? Or running wire under carpet through drain plug in floor and putting antenna behind toolbox on top of bed?? It also says I can install it inside truck with this goofy 2 1/2" metal plate stuck to dashboard but due to looks and possibly bad reception I thought outside truck would be best. So do I get my drill out or what?
Tony Montana is offline
Old 07-06-2007 | 08:24 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Pull out your third brake light, and run it out the top dead center of the opening, and place the antenna on the roof. I did this with my Sirius, and it works/looks great. Re-install with some silicone for extra sealing, and make sure you pad/protect the wire with some shrink wrap/electrical tape as it exits to avoid abrasion issues.
Sydwayz is offline
Old 07-06-2007 | 08:33 PM
The BAD Guy
Great idea Brian Dam now I can't drill through the roof of my 50k truck I am so dissapointed
Old 07-06-2007 | 11:25 PM
On all the systems in my rigs I mount it up on the dash center as close to the windshield as possible. Never had any troublw with them this way at all.
JPD Motorsports is offline
Old 07-07-2007 | 08:55 AM
Default check this
I have used the A Pillar installation on several of my trucks without a problem. Completely hidden. If it doesn't get a good signal you can always put it somewhere else.
http://www.vehiclepath.com/installation.html
irepo is offline
Old 07-07-2007 | 10:17 PM
Put it where ever it is the neatest looking for visual...I ran through one of the cab markers in the center..behind it right up on it touching.
Byrdman is offline
Old 07-08-2007 | 06:13 AM
From: A tree somewhere in the woods in Clarcona Fl.
On my f350, I did it sydwayz way, pulled the 3rd brake lite and ran the wiring for my xm up through there.
Slick02 is offline
US1 Fountain
Fountain
15
07-15-2014 11:19 AM
GoFastSonic
General Racing Discussion
6
05-25-2008 08:44 PM
JIMB
6
07-13-2005 06:46 PM
Pure Energy
06-23-2003 10:37 AM
