454 Mag Efi Fuel Pressure
I HAVE A GEN V 454 MAG EFI. WITH 500 EFI CAM AND GIL EXHAUST. IT RUNS SO RICH I CAN'T KEEP PLUGS IN IT. DOES SOMEONE KNOW THE STOCK FUEL PRESSURE FOR A STOCK 454 MAG ?
ive got 20 bucks that says that the water temp switch ( not the gage sender, the water temp SENSOR ) is unplugged or you took the thermostat out...
only way its fuel pressure is if the return line is blocked solid
