boat wont go in forward >
Old 07-08-2007 | 10:36 AM
Default boat wont go in forward
Last weekend leaving the marina i pulled my boat out of forward to neutral when i went to put back in forward wouldnt go . Still got reverse no noise or nothin . Any help would be appreciated .
La hustler is offline
Old 07-08-2007 | 05:09 PM
What drive?
Hydrolift is offline
Old 07-08-2007 | 06:46 PM
bravo one
Old 07-08-2007 | 07:08 PM
check gear case fluid
sonic28 is offline
Old 07-09-2007 | 06:09 AM
hp500efi's Avatar
Member #9
check your shift cable
Member of the Liquid Jungle
hp500efi is offline
Old 07-09-2007 | 06:49 AM
just went through the same thing and mine was the clutch cone in the upper.
good luck
rssteiny is offline
Old 07-09-2007 | 06:30 PM
good luck
I too had this problem.
Old 07-09-2007 | 07:48 PM
thanks fellas
Old 07-10-2007 | 09:20 AM
If you have recently pulled the lower unit for a water pump replacement, check the shift linkage. There is a little tang that should be pointing forward. If this was off when you re-installed it, it will lock up on you. also could be coming from the washer that fits on the shift linkage from the lower unit.
This is coming from an alpha one guy!
wesleyh is offline
Old 07-10-2007 | 10:44 PM
Might also try this ... pull the back cap off of the out drive, and check/clean/grease the spring loaded ball/detent mechanism. It can get packed with crap, and hang up.
Kidnova is offline
