350 mpi cranks but wont start >
Old 07-08-2007 | 10:54 AM
Default 350 mpi cranks but wont start
After running the boat friday the port motor stalled and wont restart. It will run on starting fluid. I swapped the computer with my other motor and still no luck.
area51scarab is offline
Old 07-08-2007 | 03:37 PM
Trippin's Avatar
Sounds like a fuel pump failure, you're out of gas, or somewhere in-between. The ECM is the most unlikely culprit.
Trippin is offline
Old 07-10-2007 | 05:21 AM
Iggy's Avatar
I agree, if it runs on starting fluid then there's a fuel problem. Pick up an EFI fuel pressure gauge and see what, if any, presure you'r getting. Could be as simple as the fuel cut off switch (oil pressure activated) or a pump gone bad.
Iggy is offline
Old 07-10-2007 | 06:17 AM
Pwrbt33's Avatar
Two questions, when you turn the key on do you hear a pump run? If yes, unplug the lift pump at the fuel sep filter and try again. Do you hear a pump run on key up? If not, the high pressure pump is bad.
John
Pwrbt33 is offline
Tidal Sails
12
07-31-2007 02:40 PM
Pismo10
18
07-04-2007 07:04 AM
Tidal Sails
1
07-03-2007 04:43 PM
Donzi502
13
12-08-2006 05:26 AM
boomer
0
06-17-2006 08:24 PM
