Formula 242 LS >
Formula 242 LS
Formula 242 LS
Old 07-10-2007 | 10:47 AM
Default Formula 242 LS
Here's the latest on my repower/re-prop situation. The 23P Mirage (non-plus) is where we started-- it was my prop prior to repower. We ran 66 MPH on GPS at 5500RPM with six people, coolers, and about 40 gallons of fuel. I had more throttle but didn't want to get up on the rev limiter which is set at 6000RPM.
I've run a 27P Mirage Plus and seen 68.4MPH on GPS with five people, coolers, and 60 gallons of fuel at 4900RPM. We're crusing at 50-55MPH at 4000RPM.
The motor is a custom-built 454 bored 0.060 (496ci) dynoed at 612 HP (5700RPM) and 615 ft-lbs. torque (4900RPM). Drive is a Bravo One 1.5 ratio.
Obvious question is where to go from here for top speed? Judging by other 242 repowers, I should be able to flirt with 75MPH. The boat is coming on plane well at 1/2 throttle and behaving flawlessly with the three-blade props.
chewymalone is offline
Old 07-10-2007 | 07:49 PM
throttleup's Avatar
A stock 23P Mirage Plus or a Labbed 25P Mirage Plus for a 3B. Or 22P stock Bravo I or a 24p Labbed prop from the details you provided.
Julie
throttleup is offline
Old 07-26-2007 | 10:46 AM
Thanks for the recs Julie. I have access to a Hydromotive 24 QIV. With the Formulas being stern heavy, what do you think about trying it?
h2oboy
06-17-2008 11:05 AM
schizm
08-06-2007 04:36 PM
SUPER AIR
12-13-2006 08:58 AM
SLIP AWAY
08-08-2006 09:21 PM
