25 OL 425hp vs 375hp >
Old 07-11-2007 | 03:58 PM
NoQuarter
Default 25 OL 425hp vs 375hp
Has anybody driven both boats... late model, 2001- 2005? I am curious about the performance differences.
I have read that there is little top-end difference (not sure about that), but what about out of the whole?
I am asking because I have found a couple pretty sweet, super clean 25s, but both with smaller power.
Thanks in advance!
Old 07-11-2007 | 08:10 PM
about 3 mph, and yes you get out of the hole quicker.
Bad-Intentions is offline
Old 07-11-2007 | 09:01 PM
yesrej's Avatar
there are alot of 25s in good shape out there. you will find the one you want.
yesrej is offline
Old 07-11-2007 | 10:22 PM
jeff32's Avatar
I had both. If I had the choice I'd choose the 425. But the 375 is still impressive! 3-4 mph top end is about right. hole puch? did not really saw a big difference but never really tested both on that subject... just driving them around...
jeff32 is offline
Old 07-12-2007 | 12:02 AM
jonyb's Avatar
I've run my 25 powered by the 496mag next to a couple 25's with HO"s, and there's not really any difference other than if I'd bought an HO from the dealer it would've cost me several thousand more. As I said in another thread, the only difference is a cam and tune (on the ECU).
I've got my 2005 25OL for sale in the classified's here
jonyb is offline
Old 07-12-2007 | 07:38 AM
haulinvols's Avatar
www.Bajaboatowners.com
True, couple miles an hour faster with the HO. Out of the hole I have not really felt a difference seat of the pants. I did notice the cruise speed was a tad better as well at equal RPM. HO motor has a 5000rpm rev limiter and the mag is at 4800rpm.
Keep in mind that you will also get the Bravo X drive with the HO motor.
haulinvols is offline
Old 07-12-2007 | 08:57 AM
NoQuarter
Thanks everyone!
Based on the responses, either motor would work for our needs... I would prefer the X-drive, though.
Thanks again,
Tom
Old 07-12-2007 | 08:41 PM
UNSANE's Avatar
I might be wrong on this but I thought that some of the internals were different between the two such as a different crankshaft and such. But I do know that the HO version should have better resale value along with an X drive. Good luck in your search, they're pretty cool boats.
UNSANE is offline
Old 07-12-2007 | 09:12 PM
tblrklakemo's Avatar
SeaRay Sundancer
Nope....cam and ECU are it. Some folks are saying the throttle body has a diff part number too, but you should get an honest 425hp out of a cam and ECU swap.
tblrklakemo is offline
DesertRage
Swap Shop
13
08-29-2021 10:02 PM
Stormrider
12-22-2006 01:53 PM
fountainsue
6
03-25-2003 07:29 PM
bcoffield
12-04-2002 06:52 PM
bcoffield
Baja
6
03-19-2002 04:32 PM
