Trans temps ?
Old 07-12-2007 | 03:15 PM
Default Trans temps ?
On a Borg warner trans C 72. Is the larger pipe plug where the press & temp senders should be ? what is normal temp ? If temp goes up is it too late (the damage is done) . what temp will be a sign that you might have the beginning of some trouble . thanks 1
scarab insanity is offline
Old 07-12-2007 | 06:42 PM
this will give you some insight..
http://www.offshoreonly.com/forums/s....php?t=129000:)
open87 is offline
Old 07-13-2007 | 08:39 AM
Scarab3DMC's Avatar
Thanks Bro...ya beat me to it !!!
Scarab3DMC is offline
Old 07-13-2007 | 12:06 PM
nah... just 1 of those things in my head...
i am actually in the process of plumbing my engine and trans ...running -10 on the trans and put a 1/8 npt right before oil goes back in the trans ...
figure , it's run it's course through the system and that would be a good place to check the pressure...
if i'm wrong ....someone please correct me...
open87 is offline
Old 07-13-2007 | 12:10 PM
Scarab3DMC's Avatar
Marc Bamm told pressure is more important than temp.. he told me to take the temp sensor out and use that port for pressure
Old 07-13-2007 | 11:09 PM
Default I hear ya
I replaced all of my gauges and carbon fiber dash , Auto Meter marine only made trans temp 2 5/8 so thats what I went with. I called today , they dont make a marine press that goes up to 200 or 250 PSI . I picked up a mechanical oil filled gauge that I will screw into the trans , Better than nothing, Im always checkin under the hatch anyway !
thinkin of puttin a tee in so I can read both . what do you think ? Cant hurt .
Old 07-14-2007 | 06:54 AM
livorsi or stewart warner...i would think auto meter should make 1 , might not be marine , but ,so what...it's a boat...you always continue to spend!!
that never stops...
open87 is offline
Old 07-14-2007 | 03:51 PM
in witch hole would you put a pressure gauge in on that trans. the smaller one one the rear or the larger one i think you should have about 180 psi anyone know exactly?
greg bakker is offline
Mr Gadgets
58
12-21-2007 11:54 AM
BobbyB
15
08-08-2006 09:46 AM
Wally
6
06-27-2006 08:22 AM
Madmax
4
09-16-2002 07:41 AM
hystat
2
05-27-2002 05:35 PM
