flywheel issue >
flywheel issue
flywheel issue
Old 07-13-2007 | 08:09 AM
ROB FREEMAN's Avatar
Default flywheel issue
changed flywheel now have slight howl in bellhousing area drive slid in good although , alignment issue or what ! thanks rob
ROB FREEMAN is offline
Old 07-13-2007 | 01:25 PM
CcanDo's Avatar
Did you " Dial the bell housing and flex plate in" ?
The flywheel/crankshaft CL are the starting index point. Centerline of the flywheel and flex plate are to match the crankshaft centerline, any variation is run out.
Dowel pins are located at the top of the engine block. The bell housing reciever holes may have excess tolerance. Or, there may be other reasons for misalignment.
Misalignment may cause vibration,starter engagement problems and shorten bearing life.
You can use a magnetic base dial indicator snapped to the slowly turned crankshaft to find an acceptable tolerance and location. In some cases, offset dowel pins are required.
As I recall, Marc at Bam may know that tolerance.
CcanDo is offline
Old 07-13-2007 | 05:32 PM
im lost any further help to clarify this will be appreciated rob
Old 07-14-2007 | 01:03 AM
Why did you change the flywheel? Did you use the correct "type", internal balance (zero dynamic balance) or external balance (intentional offset dynamic balance)?
Falcon is online now
1BIGJIM
1
01-17-2007 07:39 PM
russ
0
07-21-2005 04:35 PM
wetterthebetter
3
01-30-2004 10:31 PM
Bob280Silencer
3
01-30-2004 05:49 PM
