Best sounding mufflers >
Old 07-16-2007 | 10:48 AM
Default Best sounding mufflers
I may need to replace my CMI sound elimination mufflers but I do not want anything that is much louder.
Any suggestions for a more deep sounding mufflers that work with an HP525? The CMI's are OK sounding, mine melted from an overheating issue...see were the track slides.
They are stuck in a slightly open mode and may be too loud at idle and then may rob some power at WOT?
I need to pull the trigger shortly.
Thanks,
Jamal
S4Hadi is offline
Old 07-16-2007 | 01:44 PM
Elite Marine's Avatar
Jamal
Those must be the original CMI Mufflers. The new ones are all SS and therefore do not have this issue.
If we can get you a new pair, let me know. We'll give you a very nice deal for upgrading.
Kirk
Elite Marine is offline
Old 07-17-2007 | 12:05 AM
Thanks,
Jamal
Send them into CMI, they can rebuild them. Or, for a few extra $$, they can update them to the new version; all stainless and a finer looking and performing muffler.
Bawana
Bawana is offline
Old 07-17-2007 | 12:13 AM
Jamal, I would not run that 525 if the muffler will not open. At WOT you will have too much back pressure. Get them rebuilt, or call Kirk and get a new updated version if CMI can't do anything for you.
Bawana
Bawana is offline
Old 07-18-2007 | 02:43 AM
Thanks,
Jamal
Straight pipes with captains call..... That sounds the best!
ghittner is offline
Old 07-18-2007 | 08:27 AM
Captains Call system would be nice....I think that would be quite involved to retro fit it, wouldn't it?
I am debating if I should get another clamp on style muffler, or since I have most of the exhaust/muffler already appart to go ahead and install a transom mount unit?
Besides looks, is there an advantage to have a transom mount muffler?
Jamal
S4Hadi is offline
Old 07-18-2007 | 11:02 AM
I have these in stock for 525 with CMI sport tubes 50 percent off
Attached Thumbnails Best sounding mufflers-ebay-004.jpg   Best sounding mufflers-509-big-blocks-010.jpg
brian41 is offline
Old 07-18-2007 | 11:25 AM
Jamal
The retro-fit in a stock exhaust exit location is quite easy. Howver, yes, it can be VERY involved as with mine that exit the outside rear of transom... NIGHTMARE, but when I was finished I wouldn't have done it any other way. It is SOOO nice to shut the noise off when cruising home sometimes. I run mine to 2500 RPM with no problems, above that, I switch to open exhaust.
ghittner is offline
Old 07-18-2007 | 12:15 PM
Brian41,
What is involved to install the Captains Call to my set up? How do you route the lower exhaust to/through the transom/outdrive?
How much is 50% off?
Thanks,
Jamal
S4Hadi is offline
Old 07-18-2007 | 12:20 PM
I need a good guy price on a pair of cmi's.
Can anyone hook me up?
Kirk?
Re powering my 270 s Hallett
800 hp
VegasHallett is offline
