pcv do they help >
pcv do they help
pcv do they help
Old 07-17-2007 | 07:58 PM
ROB FREEMAN's Avatar
Default pcv do they help
engine pushing dipstick out , builder says run pcv will this help or not 10.1 to 1 600 cuber says put to gether loose , all forged motor make sense , notic e steam out breathers now the dipstick comes ou t just a scocsh but does come out rob
ROB FREEMAN is offline
Old 07-17-2007 | 08:09 PM
eyezlee's Avatar
are you running a puke tank aka overflow tank? if not maybe that will help.
eyezlee is offline
Old 07-17-2007 | 10:50 PM
im open to suggestions 4 sure
Old 07-18-2007 | 02:32 AM
Something else is up here. Blow by and steam sounds like a head gasket slight leak maybe. But something....
ghittner is offline
Old 07-18-2007 | 04:43 AM
nocigarette's Avatar
I have the same problem....plumb a good vent system for your valve covers
nocigarette is offline
Old 07-18-2007 | 07:06 AM
rv
Rob,
What is the ID of your vent hose on the valve covers? If this is too small it will not relieve enough crankcase pressure and this can cause problems - oil leaks, blow by, etc.
Rick
rv is offline
Old 07-18-2007 | 09:06 AM
Default crankcaqse ventilatuon
im only running two tall breathers one on each side of valve cover id like to see a good ventilation system , the guy above looks like hes running some sort of catch can can i see better detail thanks rob hows it going rick ?
Old 07-18-2007 | 11:50 AM
rv
Rob,
Can you show a picture of the type of breather you are using. One on each valve cover should be enough for your engine, assuming they are the right type of breather. Some breathers are very restrictive and do not do much.
Don't forget about our Fun Run 7/28 out of Northpoint Marina next weekend.
Rick
rv is offline
Old 07-18-2007 | 01:08 PM
I run puke tanks k e valve covers -16 earls between also I run a oil therm. it got rid of all moisture
eliminatethis is offline
Old 07-18-2007 | 04:51 PM
Heres my venting system. click on thumb nail to enlarge
