top speed >
top speed
top speed
Old 07-20-2007 | 01:44 PM
top speed
what is the top speed you should expect from a 36' baja outlaw with twin 502 mags 24p 4blade prop 1/2 tank of gas on a light chop? anyone out there getting better than 63.9mph gps? is there more speed there that i'm not tapping into ? don't want to put prochargers on just yet. thanks for your help
KDAWG is offline
Old 07-20-2007 | 04:26 PM
Smitty's Avatar
What is your maximum rpm attained?? Sounds like you are close to where you need to be. Remember the 36 is a big heavy hull so it will take alot of power to go significantly faster. I speak from experience.
Smitty is offline
Old 07-20-2007 | 04:42 PM
If it has 502 MPI's in it, it's probably before Baja
raised the X dimension on those, and the 4 blades
may be costing you a couple mph up top.
I remember seeing boating mag test one back in
98' or so W/502's and it ran around 67, and it had 3 blades.
This time of year ( heat and humidity) is also not
best for getting max perf. out of them.
I'd kill to be only 3 mph off my best top speed
at this time of year a couple of weeks ago
It was - 10
JaayTeee is offline
Old 07-20-2007 | 05:13 PM
Never Enuff
You might check with Dock Holiday. He might have some information for you.
never enuff is offline
Old 07-23-2007 | 11:04 AM
thanks for the input i 'm new to the big boats and i was just wondering what to expect. we bought for the ride, at least that is what i tell my wife. need more power!!!!!!
KDAWG is offline
INDY27
Fountain
37
03-31-2008 06:21 PM
barron
Fountain
26
09-18-2006 06:17 PM
TGOR
General Racing Discussion
3
03-29-2005 08:07 PM
Excalibur502mag
3
08-05-2004 02:39 PM
shockwaveharry
8
10-15-2002 06:56 PM
