380k-planes
Old 07-22-2007 | 09:03 AM
375stinger's Avatar
Default 380k-planes
I tried posting this in the tech area. I am in need of two 380k-planes (just the actual "plane" or tab), to modify existing 280s to the 380 length. I need the style to fit a 1990 tab. Does anyone on the board have leftover tabs of the older style? Or where could I find a set of used ones to repaint if needed? We need them asap, if anyone knows any leads, etc. it would be very appreciated. Thanks
375stinger is offline
Old 07-22-2007 | 09:04 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
380 Plates only are extremely hard to come by. I have only seen two sets come up for sale in my 6 years on OSO, and I bought one of them.
Sydwayz is offline
Old 07-22-2007 | 09:58 AM
HERE'S 1 IN THE SWAP SHOP.....
http://www.offshoreonly.com/classifi...ct=3293&cat=32
open87 is offline
Old 07-22-2007 | 10:20 AM
bcschoe's Avatar
BRAD SCHOENWALD
You can use the new 380 plates. Order new plates, new lower pins, the busihings, and washers.
Call Brownie at Stainless Marine and order a new end piece for the trim indicator cable attachment.
Remove the trim hydralic cylinder and cut each side equally with clearance to fit inside the tabs.
Verify clearance on the inside edge of the tab to verify your drives will not hit the tabs at ny setting.
bcschoe is offline
Old 07-22-2007 | 10:24 AM
375stinger's Avatar
Open: Thanks, i just contacted the guy with the tab, but ill still need another one to run...lol
BC: Thanks, do you know of where I could purchase the tabs and parts required to do the switch? Thanks
Old 07-22-2007 | 12:07 PM
bcschoe's Avatar
BRAD SCHOENWALD
Any Mercury dealer. Like Tres Martin Performance!
bcschoe is offline
Old 07-22-2007 | 01:06 PM
375stinger's Avatar
Thanks! Just sent him a pm..
DJW
02-05-2004 07:51 AM
Vinny P
20
01-31-2003 08:34 PM
two-air
0
04-12-2002 01:31 PM
