overheating small block >
Old 07-23-2007 | 10:44 AM
Default overheating small block
my friend has a 87 checkmate 350 with trickflow heads.wiped out a camshaft and changed cam.now it overheats within 2-3 min of running 190-200 degrees.has new water pumps,pulled intake to check gaskets no problems,pulled t-stat out still heats up quick.could the manifolds/risers be a issue?seems like some sort of blockage somewhere
awsomethunder is offline
Old 07-23-2007 | 10:54 AM
Bravo? Alpha?
pullmytrigger is offline
Old 07-23-2007 | 11:11 AM
alpha drive
Old 07-23-2007 | 02:49 PM
TomZ's Avatar
Probably a bad water pump impeller in the drive....
You can check by starting her up on the muffs and pulling the incoming water hose to see what's coming through. Even at idle it should gush water. If not, then you've got a bad impeller or something else happening between the engine's water inlet and the drive.
Hope this helps.
TomZ is online now
Old 07-23-2007 | 04:01 PM
impeller in drive is new,recirc pump new.water out of the exhaust is wicked hot.
Old 07-23-2007 | 04:54 PM
rws's Avatar
rws
Did you check the 3/4" id hose that is behind the bellhousing? Those are known to collapse
rws is offline
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
dave911
3
06-16-2006 05:43 AM
chriscraft240
4
08-28-2003 01:17 PM
Da Patriot
44
11-24-2002 08:27 AM
