AC problem
Old 07-24-2007 | 03:32 PM
Smitty1035's Avatar
Default AC problem
Had a problem this weekend with my marine AC on my 358 Sonic. I can start the system and everything works fine, blows cold air and flows water out. It will run for about 10 mins and then the water will stop flowing and eventually the unit will shut off and give an error code. Does it sound like a water flow problem?(cleaned out strainer and found a small jellyfish but continued to have same problem after).
Smitty1035 is offline
Old 07-24-2007 | 03:37 PM
mbones's Avatar
mbones
check the pump .when you lose water flow the unit is triping out on high discharge press.
mbones is offline
Wally's Avatar
Were doomed!
i know certain models have an over heat protection that will shut the unit off...maybe the sensor is going bad or you could actually have a water flow problem. You can try running some muratic acid through the system to see if it will clean anything out that may be blockign the cooling passages in the AC unit....if its a March Pump that supply's the water you can run the muratic right through the pump as well. The parts in contact with the acid can take it with no problem....i know..we make the pumps!
-Wally
Wally is offline
Old 07-24-2007 | 03:48 PM
Wally's Avatar
Were doomed!
Actually if you want to check the flow of water...heres a really simple way of doing it. When you go to start the system for the first time...grab a bucket and catch all the water you can for one minute....before the thing shuts itself off.
Depending on what pump you have on your system heres what the pumps "should" be putting out if plumbed with the correct size lines:
LC-2CP-MD = 5 gallons/min through 3/8" inlet and 1/4" outlet line
LC-3CP-MD = 8 gallons/min through 3/4" inlet and 1/2" outlet line
LC-5CP-MD = 14 gallons/min through 1" inlet and 1/2" outlet line
Now if theres a smaller output line then whats listed above the output will be less.....and if you dont have the proper size inlet hose the output will be less as well...along with possible starvation and damage issues in the long run.....
-Wally
Wally is offline
Old 07-24-2007 | 04:10 PM
Smitty1035's Avatar
When I start system everything seems to flow fine. What would cause the pump to stop working? Everything was factory installed by Sonic and has worked fine in the past. When I used it for the first time in the season I had to remove the hose from the pump to drain the anti freeze out and system worked fine.
Old 07-24-2007 | 04:14 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Maybe your pump is going bad and it takes about 10 min. before it locks up and shuts down, shutting down the AC?????
Just a thought, but it sounds like a water flow issue.
My Mermaid will shut the compressor down after 1 min of no water to cool. The fan and pump will still run though.
US1 Fountain is offline
Wally's Avatar
Were doomed!
unless it was run dry for an extended period of time or had some debree stuck inside causeing damage there should be no realy reason for the pump to fail.....they are very durable pumps........or if it wasnt winterized properly and the internal cooling tubes ruptured letting moisture intot he motor itself...
-Wally
Wally is offline
Old 07-24-2007 | 04:20 PM
Try priming it with a hose.I had one that would pump but never be fully primed unless you hit it with a hose.The pumps if their like mine are bullet proof.
tommymonza is offline
Old 07-24-2007 | 07:56 PM
Smitty1035's Avatar
Sounds like I need to flush the system. Hopefullty that will work.
Spooln
12
08-15-2007 09:58 AM
Brandon
12
08-14-2007 08:10 PM
Baddogg
10
08-07-2004 09:14 AM
timucin
25
12-05-2003 12:00 AM
