Check your trailer !!!!
Old 07-29-2007 | 11:20 AM
Smitty's Avatar
Default Check your trailer !!!!
Just thought I would share what happened to me yesterday.
I was bringing the boat home to do maintenance and on the way I was stopping and then all of a sudden I had no more trailer brakes. Thank God for Powerslot rotors and Hawk pads on my F-350. I had to use all it had to stop the 15,000 lbs that was behind me!!!!
The reason this happened is because on my 2000 Heritage triple axle trailer, the brake line was rusty and rubbed thru where it exits from inside the frame tube in front of the first axle. It burst because the rust and rubbing weakened it at that spot. A trip to the parts store and 3 hours labor and I am back in business. I bought coated line and I put a rubber hose over the line to shield it where it goes in and comes out of the trailer.
If you trailer alot take the time to check yours out. Don't find out the hard way like I did !!!!
Smitty is offline
Old 07-29-2007 | 08:08 PM
buck183's Avatar
Do me a favor and check it out again before you leave for LOTO Dave.
Buck
buck183 is offline
Old 07-29-2007 | 10:53 PM
RedDog382's Avatar
In 4 years, I have had to replace the same piece twice from rubbing and leak inside the frame of my Eagle trailer.
RedDog382 is offline
Old 07-29-2007 | 10:55 PM
30 outlaw 2005's Avatar
Dave. Did you get a chance to get out on the water this weekend? I'm going to have to check out my trailer. If in not mistaken I think all my lines run out side of the axels...
30 outlaw 2005 is offline
Old 07-30-2007 | 07:46 AM
Smitty's Avatar
I was out most of yesterday. It was an awesome day !!!
The brake line I had to replace was from the master cylinder to the first junction point in front of the first axle. All of the lines that feed individual calipers are outside of the axles. Its the single line that you need to keep an eye on.
Smitty is offline
Old 07-30-2007 | 01:42 PM
Always use stainless steel braided brake lines!!!
Pro1 is offline
Old 07-30-2007 | 04:07 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
Smitty, straps are on the way.
WARPARTY36 is offline
Old 07-30-2007 | 04:27 PM
Smitty's Avatar
Warparty36
Thanks !!! Can't wait to have some "real" straps !!!
Smitty is offline
Cattitude
Pantera
7
09-06-2006 08:38 PM
sonic31
06-20-2005 02:55 PM
C_Spray
05-02-2005 08:46 PM
GO4BROKE
03-20-2005 10:15 AM
