Motor Guru's..Need help with 496 low oil pressure!! >
Old 07-30-2007 | 06:54 PM
Default Motor Guru's..Need help with 496 low oil pressure!!
I have 2004 496 HO's. Cold start oil pressure is 40-50 lbs...After warming up it will stay at about 20...When you run it after plain it starts dropping till the warning buzzer goes off...I put a mechanical gauge on it and it is dropping oil pressure. Changed oil (straight 40) No change.. Has anyone ever heard of 496's doing this?
speedreeder is offline
Old 07-30-2007 | 08:16 PM
UNSANE's Avatar
What is your oil temp reading? I know on a 525 at least when my pressure goes down and the temps go up, the filter has collapsed and it's bypassing the oil cooler. Try changing the filter first would be my guess (cheap and easy)
UNSANE is offline
Old 07-30-2007 | 08:24 PM
Yes, I put new filters on when the oil was changed. No oil temp gauge but, Shot the oil filter with temp gun..205..Thanks for the suggestion....
Old 07-30-2007 | 09:10 PM
How many hours? Does the computer read the same as guage?
turnerrd is offline
Old 07-30-2007 | 10:15 PM
200 hours. The computer is saying same thing. Pretty sure it is maybe mechanical, But I have never had a motor with so few hours on it, Do what this is doing.?Anybody ever had an oil pump problem?
Old 07-30-2007 | 10:23 PM
I haven't heard of problems with that motor but have had customers who had over filled with oil have similar problem.
Jim
MOBILEMERCMAN is offline
Old 07-31-2007 | 02:58 PM
The oil levels are right on. Has anyone ever heard of spinning a bearing and not making a knocking noise. One slides around under the other.? Just wild ideas before pulling out..!
Old 07-31-2007 | 03:25 PM
Did it happen all of a sudden, like one day it was fine ,or was it a progressive drop?
Jim
Old 07-31-2007 | 06:25 PM
all of a sudden! No noise, No loss of power?
Old 07-31-2007 | 06:56 PM
Well it seems you will end up pulling the motor and then the oil pan. As you know its any bodies guess. I had an engine guy tell me he found the pull off seal from a oil container in the oil pump screen. Maybe something freaky like that was happened. A cracked pickup or clogged screen. Just my two cents. Good luck.
Jim
GoCiggie31
7
08-19-2007 06:07 PM
SCANDINAVIAN
0
06-10-2007 03:39 PM
GNJ
17
11-08-2006 10:48 AM
FlyFast
13
05-10-2004 11:39 PM
1Gunner
1
06-27-2002 12:21 PM
