Mildew removal from seats
Old 07-30-2007 | 08:09 PM
Default Mildew removal from seats
The boat I am buying has quite a bit of mildew on the seats from sitting with the cockpit cover on it with no vents for about a year and a half. What have you all found to be the best for mildew removal from vinyl seats? Thank you in advance.
Brandon
Brandon is offline
Old 07-30-2007 | 08:30 PM
firstoffshore's Avatar
Mr Clean Magic Erasers
firstoffshore is offline
Old 07-30-2007 | 08:32 PM
Brandon
Mix 1 part bleach to 3 parts water in a spray bottle. Works great on stubborn mildew and keps it from coming back. Then use a good vinyl restore product to put the shine and oils back.
gerritm is offline
Old 07-30-2007 | 08:33 PM
I thought about those but have never used them and didn't know if they worked on mildew. Thanks
Brandon is offline
Old 07-30-2007 | 08:36 PM
Solution of Jo Max and bleach. Use on white surfaces. Test a small section of color to make sure it does not affect the color before you spray the whole thing.
I used it on a boat that had a mildew prob, and it did wonders. It did not affect the colors on the boat, i did the whole thing.
The Jo Max bottle has instructions on the ration of bleach to jomax to water to be mixed.
Mackattack is offline
Old 07-30-2007 | 09:11 PM
BY U BOY's Avatar
lysol tub and tile with bleach. Im telling you guys this chit works wonders.
BY U BOY is offline
Old 07-30-2007 | 09:43 PM
Smitty's Avatar
Clorox cleaner with bleach and a small soft brush, then wipe dry.
Smitty is offline
Clorox Clean Up. I think pretty much anything with bleach will work. If the stains don't come all the way out right away, let it sit in the sun.
Griff is offline
Old 07-30-2007 | 10:15 PM
Cool, thanks guys. I figured about any sort of bleach solution would probably do it but wanted to see what everyone else thought as I didn't know if the bleach would hurt thte vinyl. Does anyone have any idea how much it would cost to have 2 bolsters, combing panels, rear bench and engine hatch recovered? There are a few tears in it but not too bad so I plan to do a real good cleaning and possible recover all seats in the winter. Heres a few pics of what I will be working with. http://www.lakewideyachtbrokerage.com/1507.htm
Brandon is offline
Chart
04-29-2008 07:38 PM
BajaRunner
02-22-2005 04:44 PM
CAPTAIN CHUCK
5
10-26-2004 06:16 PM
Chris288
10-22-2004 05:12 PM
yzbert
Fountain
8
10-03-2002 08:43 PM
