Installing silent choice on a 20' Outlaw >
Old 08-02-2007 | 09:56 PM
Default Installing silent choice on a 20' Outlaw
Has anyone inslalled swithable exhaust . It is a 5.0 MPI , alpha. It has only straight thru now.
fox 2 is offline
Old 08-04-2007 | 11:20 AM
We have been asked a thousand times to do that upgrade, and there is not enough room for the Y-Pipe. If you figure it out, let me know.
flying33 is offline
Old 08-06-2007 | 02:53 PM
From Baja there is a option called Quick & Quiet ll .What does it mean.
fox 2 is offline
Old 08-06-2007 | 03:29 PM
Quick & quiet 2 is non-switchable, so it splits between transom and hub all the time. Its stock on them now. So yes a y-pipe will fit. Quick & Quiet plus is switchable for thru transom, or thru hub.
OL30 is offline
Old 08-06-2007 | 10:20 PM
Thats what I thought , there looks like lots of room to me. It is on the 202 Islander which I was told is the same hull. Corsa says it will fit, but you have to pull the motor. I was just wondering if someone has done it .
fox 2 is offline
Old 08-07-2007 | 08:13 PM
flying 33 I went today and looked at a Ilander 202 and it had factory corsa quick and quite ll on it . There is not a lot of room for it but it is done.
fox 2 is offline
Old 08-08-2007 | 08:00 AM
Dock Holiday's Avatar
Charter Member #34
Is it that loud?
I took it off of my boat!
Look at mufflers that clamp on or do the new turn down pipes that are under water while off plane. Both are much cheaper and easier and very effective.
Dock Holiday is offline
Old 08-08-2007 | 08:13 AM
Sydwayz's Avatar
Forum Regulator
Originally Posted by Dock Holiday
Is it that loud?
Same thought I was just going to post.
Look into external full time or switchable mufflers; or exhaust tip turn downs that put the exhaust underwater when you are on plane.
www.trickmarine.net carries all of them, as well as www.teaguecustommarine.com
Sydwayz is offline
Old 08-08-2007 | 05:27 PM
Hi Dock, I got the cover you sent me it looks great. It is loud for the one lake we boat on . But that is a great idea with the other mufflers, I will look into it.
THanks everyone
fox 2 is offline
TSPM
Baja
1
06-25-2007 12:41 PM
kordisoffshore
02-23-2005 04:57 PM
Outdrive1
6
02-11-2005 09:35 PM
flipj5
5
03-31-2004 08:32 PM
edb07
3
07-22-2002 01:03 PM
