New big block, what prop to use??? >
Old 08-04-2007 | 03:35 PM
Default New big block, what prop to use???
I just purchased my first big block, and was wondering what prop to use for the best performance. The boat is a 23' Mirage with the 454 Magnum and the Bravo outdrive. What prop will give me the best performance, and what kind of rpm's should I expect? Thanks for any help you can lend!
Nate Sears is offline
Old 08-04-2007 | 07:57 PM
Best top end prop will probably be a Mirage Plus. Most likely a 23". You want to prop it so the engine turns 5000rpms with that engine.
Griff is offline
Old 08-05-2007 | 11:59 AM
jeffbare's Avatar
What gear ratio is the Bravo? Is it a 1.5/1?
jeffbare is offline
Old 08-06-2007 | 08:17 AM
I'll cehck the gear ratio, and start looking for a Mirage Plus, thanks!
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
Crazyhorse
02-01-2004 10:54 AM
chriscraft240
4
08-28-2003 01:17 PM
Da Patriot
44
11-24-2002 08:27 AM
