Mercruiser MX 6.2 MPI troubles?
Could be.
This small-block is rated at 320 hp replacing the 310 hp big block. The weight savings looks good on paper, but this little stroker motor is having many problems the non-stoker motor, 5.7 MPI, 300 hp is not having.
seems they break the piston first then the rod. all have been under warranty between 10-200hrs. We also have no problems with the 350 mag or 5.7 Ed how many of these have you had because I thought merc said we were the only dealer in the country with this problem?????
Phil
Phil
4.5 quart oil capacity. So, using same pan as the 5.7L/350 MAG but Merc changed the dip stick to keep the crank out of the oil? How many people are overfilling this motor (thinking they are 5 quart capacity) and aerating the oil?
