help 496 ho
I have an '02 496ho. When I run out for appx. 30 minutes the boat will stall and will not restart for appx 20minutes. Almost like it is vapor locking. Any suggestions as to where to start
Was the fault an ACTIVE fault, or a stored fault? It's not uncommon to have stored cam and crank sensor faults even when the sensors are not faulty. If the fault is an active fault, then you have a bad sensor.
Dave
Dave
