WHat would be the effect if the motors were making different horsepower and torque? >
Old 08-09-2007 | 01:41 PM
phughes69's Avatar
Default WHat would be the effect if the motors were making different horsepower and torque?
I am rebuilding only one motor in my boat. The rebuilt one will be a 468 with similar compression (7.5:1, turbo motors) to the other one. Both motors will have the same camshaft, intake, heads etc. The only difference will be the newer one will have 14 more CID than the other and the newer motor will have less leak down. The older motor has about 15% leak down. If both motors are running at the same RPM, how will this affect the way the boat handles?
phughes69 is offline
Old 08-09-2007 | 01:43 PM
I would guess very little. because
hp difference is not going to be that different.
jeff1000man is offline
Old 08-09-2007 | 03:57 PM
phughes69's Avatar
That is what I was hoping for. The diference in HP between the motors will be about 30-40.
Old 08-09-2007 | 04:35 PM
offthefront's Avatar
Circles ............
offthefront is offline
Old 08-09-2007 | 04:47 PM
thunderusone's Avatar
Your throttles may be a tad off.
thunderusone is offline
Old 08-09-2007 | 06:03 PM
This happens in airplanes all the time. mid-range throtels will be different but you probably won't even notice. WOT you may experience a different TOP RPM, maybe 50 rpm between the motors.
baronbob is offline
RMPRam
Wanted
5
09-23-2008 08:33 AM
Bad Ass Industrial
Ultra
4
03-13-2008 09:21 AM
cobra marty
5
11-29-2003 04:32 PM
BAD-HABIT
5
03-10-2002 12:52 PM
sheikman
15
02-08-2002 09:18 PM
