one cylinder no compression? >
Old 08-09-2007 | 10:06 PM
tgersx's Avatar
Default one cylinder no compression?
trying to help my buddy he, he has a miss at about 4500 rpm so we pulled the plugs everything looked good, so we did a compression test and on number 7 we are getting erratic pressure sometimes we get 120psi and 90 psi and then it will crank for a while and have no compression, all the rest of the cylinders have 145psi. no miss down low and it sounds great? can it be a valve? i dont understand how we can sometimes have compression. its a chevy 572 big block
thanks
tgersx is offline
Old 08-09-2007 | 10:18 PM
This happened to me and it was a broken valve spring.Pull the valve cover to make sure. You may get lucky and be able to fix with little disassembly. Mike
Michael Garibay is offline
Old 08-10-2007 | 07:55 AM
Angry
Man, I never get that lucky.
kennyo is offline
Old 08-10-2007 | 07:56 AM
OldSchool's Avatar
Aint that the truth!!!!!!
OldSchool is offline
Old 08-10-2007 | 09:04 AM
Every time I have seen a broken or weak valve spring it will POP (backfire) at higher RPMS. The valve dosen't get closed in time because of the spring.
1BIGJIM is offline
Old 08-10-2007 | 09:09 AM
No evidence of moisture in #7?
Sounds like a valve sticking. Could be a weak or broken spring as mentioned.
Edward R. Cozzi is offline
Old 08-10-2007 | 09:45 AM
I snapped a rocker stud on the exhaust side once...broke a rocker arm in half once...seized a lifter once, etc, etc, etc.
Let us know what you find.
Back4More is offline
Old 08-10-2007 | 10:39 PM
tgersx's Avatar
well couldn't any cracks in the spring for the exhaust valve but i replaced it anyway and now all is fine. 150psi of compression!
tgersx is offline
Old 08-11-2007 | 03:55 AM
Good news. It was weak, but not weak enough to be felt at lower rpms or cause a backfire. Your buddy should consider himself lucky.
Griff is offline
Old 08-11-2007 | 02:32 PM
Congrats on the simple repair but I would be concerned with the rest of the springs so stay alert.Mike
