Bravo - Alpha
Old 08-14-2007 | 08:43 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Bravo - Alpha
Does anyone know the measurment from the prop shaft to the drive input shaft on a bravo and a alpha.Thinking of switching from a alpha to a bravo and don't know if it is longer between shaft's. Thinking my prop might get to deep in the water unless I raise the X demension. Thanks JOHN
Fenderjack is offline
Old 08-14-2007 | 10:11 PM
t500hps's Avatar
21 and 42 footers
You do realize that you have to replace the entire transom assembly too don't you. If the dimensions are off you can move the motor up or down to account for the diffrence in height.
(sorry, I don't know the height answer to your question)
t500hps is offline
Old 08-15-2007 | 10:45 AM
Any interest in a complete used bravo set up ? I think the gimble is an 04, drives a 1.5 and abit older with a nose cone. Rams pump bravo 24p 4 blade . Probably rite at 4k
z.zuperboat is offline
Old 08-15-2007 | 03:26 PM
From Ujoint to propshaft centerline the Bravo 1 and Alpha 1 are the same. I cannot remember the actual number but it's 21" ?/?. I was going to swap a Bravo inplace of my Alpha and asked the same question as I thought the Bravo would put the prop lower in the water.
Ryan00TJ is offline
evaluex
5
08-21-2007 11:03 AM
jtybt15
08-25-2005 08:41 PM
UPTHECREEK
3
07-11-2004 08:57 PM
BAJA WILL
04-07-2004 07:28 PM
nauticaL ILLUSIONS
1
02-21-2004 08:29 AM
