Swap Cam with out pulling engine
Has anyone ever swaped a cam without pulling the engine out of the boat? I was told it could be done but can't figure out how to do it without dropping the oil pan? I have a 420 HP carbed engine. Thanks
You have to trim the inner corner edge of the lower seal at both corners to get it to go back into the oil pan if you try and do it without dropping the pan.
Plus you need to have enough front clearance to get the cam out.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I have enough clearance in the front to pull the cam your saying I have to trim the inner corner edge of what? You lost me.
I've tried this method several times with no luck. Installing the timing cover with the pan in place is pretty difficult and EVERY time I've tried it leaked badly. If you want to do it right (and only once) pull the motor, flip it over and get 'er done!
Good luck,
Kurt
Good luck,
Kurt
I agree with Biggus although you can do it in the boat (I have drilled holes in rear bulkheads so I had room to pull them before) Its a pita. On a gen VI you need to drop the pan down even further or you will most likely break the ears off the timing chain cover ( 6 bolt cast alu type cover) on the mark IV w/ a sheet metal timing cover you can bend them a little. If you do it go heavy on the RTV. If it leaks another coat of RTV is a bandaid that might get you through the season. good luck SC.
If you have the means though,,,, pull the engine,,,, I have done them this way, and have had luck,,,,but your asking for an oil leak, and doing it in the boat should be a last resort.
Chris288
03-29-2005 10:09 AM
JGB
40
02-16-2005 10:26 AM
