Need power steering lines on the rams
I have had 2 failures on my mayfair steering line on the steering rams.The rubber is failing inside the fitting ,the hose it fraying on the end and coming apart. I have the tool from Marine Machine to put themtogether etc, The rubber line are I guess getting old?
I want to get some made ofStainless braided line made up with the stainless fittings.
Were can I get these at a reasonable price ,any sugestions??
Rob
Rob
Check your local Hydraulic hose shops. They can hook you up or tell you where to go. We have a couple of places here that do it. Are those ends the kind you can disassemble with wrenches? If they are you should have no problem.
I was thinking if I got some they were crimp style they may hold up better?My local shop doesent have shet,there division on the coast doesent have it either.Remember im in Mississippi
Been calling all day, busy or call want go tru.
I tried CP Perf they have them already made up ,shopping around now.
http://www.imcomarine.com/nvcatalog/imco2007.pdf they make all kinds of lines dont know if it will fit your steering but go check it out .
