cooling problem >
cooling problem
cooling problem
Old 08-22-2007 | 01:19 PM
later's Avatar
Default cooling problem
have a friend that has a 97 4.3 efi with a bravo three out drive, water tempeture goes up to 185-190 then will drop back down to 120 then a few minutes later rises back up the 185-190 and then will drop back down to 120, this is after he replaced the seawater pump because of a bad impeller, he then replaced the circulating pump and thermostat, any ideas.
also does any one have a serpintine belt diagram for this motor to make sure he has the belt on properly.
thanks in advance
later
later is offline
Old 08-22-2007 | 01:31 PM
Somethings wrong in the t-stat housing or possibly the water flow. I had the same thing happening and ended up putting a new housing in; fixed it.
handfulz28 is offline
Old 08-22-2007 | 02:46 PM
jhiguy377's Avatar
indeed that kind of fluctuation would seem to be thermostat based. good luck - jeff
jhiguy377 is offline
Old 08-22-2007 | 02:51 PM
I've seen similar problems caused by a bad head gasket. A quick check of the plugs will rule that out.
rdoactive is offline
Old 08-22-2007 | 03:07 PM
Did you back flush the system to get all the little rubber impeller parts out? I am willing to bet that is your problem
1BIGJIM is offline
Jim Jermain
10
12-04-2012 05:25 PM
Shore Thing
2
05-24-2005 06:17 PM
screebar
9
04-21-2004 04:12 PM
