Go Back  Offshoreonly.com > Owners Forum > Powerquest
What do you guys think of this ? >
Old 08-24-2007 | 08:00 AM
Default What do you guys think of this ?
I am going to look at this weekend. Any thing in particular I should keep my eyes out for on this model. I understand the quality during this time was pretty good. What can I expect performance wise out of twin 5.7L's. The owner says there is no hour gauge but claims the marina that services it has since new and say no more then 250 hrs. I don’t think there is any way for me to check that other then a good motor inspection. Does any one have experience with this model and twins ?? Seems pretty rare but I don’t know much. Also I can’t tell from the pics but I would guess it has alpha drives, which worries me... (Should I be worried).
The owner says he has only used it on inland lakes like Higgins and such. My intent is St Clair with and occasional drop in Lk MI or Huron. Is this hull pretty good in the rough?
Thanks in advance.
Vince
Attached Thumbnails What do you guys think of this ?-01011001021201041220070822e2eb1a679ee0c785c8003e0c.jpg   What do you guys think of this ?-01011101020401031120070822b30d8b82108617979d0034fc.jpg
camaro69 is offline
Old 08-24-2007 | 08:01 AM
Oh forgot to mention its a 92
camaro69 is offline
Old 08-24-2007 | 08:18 AM
Maybe I missed it , but what model is it?
Not that I can help with your answer. I have a '91 PQ Conquest 230and that is not a Conquest.
I am assuming it is a 27' or 29'
Shawn D is offline
Old 08-24-2007 | 09:21 AM
Sorry again its a 27
camaro69 is offline
Old 08-24-2007 | 03:52 PM
looks like a 29' Enticer. couldnt get twins in a 270 laser.
runafever is offline
Old 08-24-2007 | 04:10 PM
They did put twin small blocks in Lasers.
Gary C is offline
Old 08-24-2007 | 05:33 PM
I have a 92 208 viate. Single 350 mag/alpha. If you can, pull the bottom plug on the outdrive stopping the oil QUICKLY with your finger. Make sure the magnet isn't loaded with metal shavings. Covers from those years are generally wasted. My 21' cockpit cover cost 700 to replace. Give a little more for your case if it needs one. Stitching on the rear hatch was pulling apart. Vinyl work can get pretty expensive. Other than that mine is built like a brick you know what house. 350 is easy on gas. In my case I average 5-6 mpg. Adjust for twins in your case.
magstang1 is offline
Old 08-24-2007 | 09:43 PM
speed demon's Avatar
I have a 95 270 Laser with a 454 Mag EFI 385hp. I boat out of Grand Haven and the boat does great on Lake MI. Handles 2-3 pretty well, any thing bigger and you just need to put the tabs down and take it easy. I have always felt very safe in this boat on the lake. Mine does 55 - 56 pretty regularly on flat water. Best is 58 on gps. I haul alot of crap on the boat and usually have at least half tank of gas. Lighter load might give an extra mile or two more speed. If the 5.7 twins give you more speed and you have the benefit of a second engine if one goes down you can always limp back. If the speeds aren't much better a single big block might be more cost effective to run and maintain. I estimate I get about 2 mpg. Good luck in your search.
speed demon is offline
Old 08-25-2007 | 08:25 AM
Fast Forward's Avatar
Gotta be a 29. The 5.7 were pretty rare. I would guess a 60mph boat???
Fast Forward is offline
Old 08-25-2007 | 10:43 PM
Back in 92 and 93 PQ made 270 Lasers with twin 350s
the called them 270 laser twins
boatnt is offline
