Whipplecharger and t-stat >
Old 08-25-2007 | 03:52 PM
Grog's Avatar
Default Whipplecharger and t-stat
Guys-
Should I be running a water thermostat on my whipplecharged 502?
I have a problem with water contamination in my oil every 3-4 trips out and I think it may be due to condensation. Either that, or I have a leak.
My water temp rarely gets above 100 degrees. I installed a new cooler and 200 degree oil thermostat which seems to hold the oil temp right at 200. I guess I would say that it works a little too well since 220 would be better.
Any advice???
Grog is offline
Old 08-25-2007 | 04:36 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Grog
Guys-
Any advice???
Not sure on the 502 but my 500efi just has a water restrictor,water run 115-135 depending on outside temps,also had a oil threm and it doesent have condesation.You should be getting hot enough on the oil temp to not has a condesation..
Water leak maybe???
Strip Poker 388 is offline
Old 08-25-2007 | 07:05 PM
I think you are the right path by getting the oil temp to 212+. KEPP sells an thermostat that is between 215-220 degrees. Try one on one engine and see if this fixes the water in the oil issue.
BenPerfected is offline
speedreeder
Wanted
1
04-04-2008 03:24 PM
txriverrat2001
4
01-02-2007 06:00 PM
louietherigger
2
08-07-2006 05:20 PM
blueamerican
01-12-2006 08:06 PM
Sammy
4
04-23-2003 12:29 AM
