Oil squirt in Merc. 350 mag. >
Old 08-25-2007 | 05:16 PM
Default Oil squirt in Merc. 350 mag.
Older (1985) merc 350 CID mag. (300 HP) at higher RPM's (above 3500) I see oil at the starboard engine, starboard side. Not dripping, squirting out from someplace. Since the whole sides gets oilie, I can't tell where it comes from and why. Any ideas?
Help. Thx
P
PARADOX is offline
Old 08-25-2007 | 05:44 PM
P,
One thing you can do is clean it off real good, then get a bottle of leak tracing die from a local auto parts store. Put it in the oil and run it for a little while. You will need to buy or borrow an ultraviolet lamp (black light) ... it makes the die glow bright yellow and it is usually pretty easy to find the leak. A plant grow light from Walmart will work fine and is pretty cheap.
There are not a whole lot of places on a small block Chevy to leak oil. Valve covers would be first on the list, then possibly intake manifold end seals. Front crankshaft seal can make a mess, but they usually dont just start leaking all of a sudden. If something has happened to the engine internally and it has a lot of blowby, it could be blowing it out of the breathers, if so equipped. That year engine should have a pcv system I think so there would not be an open breather.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 08-25-2007 | 08:10 PM
It's been doing it for a while so I been running under 3500 RPM's. I do think it has breathers, there are some tubes going to the bilge area. Here ever it is coming from, it's not directly from the top area. mostly starboard side. mid to low are of the motor. I can't see it when we are running, only after I stop and open the engine hatch. I can't run while the hatch is up so it's a guess game.
P
PARADOX is offline
Old 08-26-2007 | 07:03 AM
Oil pressure sending unit? Oil cooler/lines?
johnny b good is offline
Old 08-26-2007 | 06:20 PM
Where does the dip stick tube enter the oil pan? Some seal with o-ring where they go into the pan, if it isn't there, it will leak only when running.
Nova 26 is offline
Old 08-26-2007 | 07:48 PM
Default oil squirt
THanks Nova.
The dip stick is on the side of the block and pretty much at the top of the pan. The only time this darn thing is squirting out oil is at higher RPM's Oils goes all the way to the starboard side of the boat. (inside) The whole side is sprayed with oil.
It's got to be some preassure related leak somewhere. I cleaned it, but I can't tell where and why. I have to try and run with the hatch open and see if I can find where it's coming from.
PS: anyone finds a motor hatch (red and white) floating in the water. IT'S MINE... !!
PARADOX is offline
Old 08-27-2007 | 08:15 AM
PatriYacht's Avatar
Here's a problem I had. I changed breathers to some made in China, Mr Gasket stuff. The foam insiden was too dense to allow the blowby out so the pressure pushed oil out of the dipstick tube. The oil dripped onto the seawater pump belt and got sprayed all over the side of the bilge. It's not hard to see it happen. Have someone sit in the back seat and crack the hatch.
PatriYacht is offline
Old 08-27-2007 | 01:59 PM
THat makes sence Patri.. Thanks,, I will try.
PARADOX is offline
BRIAN73
17
07-16-2011 06:12 AM
PARADOX
08-05-2008 11:35 AM
2 Trick Rick
6
06-20-2006 07:09 AM
Miguel
0
08-16-2004 03:05 PM
Cattitude
1
08-11-2003 05:53 PM
