1995 Sr-271 Seat Removal >
Old 08-30-2007 | 06:27 AM
Default 1995 Sr-271 Seat Removal
How Does The Rear Seat Come Out. I See The Bolts In The Engine Compartment That Come Thought, But Not Sure If There Are Any Other Hidden Ones Along The Side. Any Help Would Be Greatly Appreciated.
Thanks In Advance.
CULATER is offline
Old 09-01-2007 | 09:08 AM
Superboat Guy's Avatar
Its a tough job, the sides are bolted in. You need to remove the grab handles and the trim panels under the grab handle. Then reach inside the side compartment with a offset ratchet screw driver and a big Phillips bit there is a few screws on each side. Then remove the cup holder/ step in the arm rest and I think there is a few screws in there to. The seat fits tight and is not easy to get in and out, if its wet and soaked with water you will need a helper
Superboat Guy is offline
Old 09-05-2007 | 11:56 AM
Default re
sounds like a good weekend project. thanks for the info!
CULATER is offline
CULATER
07-25-2025 06:12 PM
stankgilr
06-20-2008 08:45 PM
88242LS
12-26-2007 07:44 PM
Hazlnut
05-18-2007 09:15 PM
olemissalum
08-25-2002 08:09 PM
