BBlades hits the target!
My Velocity VR1 likes both Hydromotive and Bravo 1 props. Hall's Propeller labbed a Hydromotive Q-IV 27" and then tweaked it a second time to allow me to reach my HP peak at 53-5400 rpm. Brett at BBlades thought he could get me more speed with a labbed Bravo 1. I started with a stock 28" to get a baseline. After labbing, he made one more adjustment for bow lift and max rpm. Running within minutes of each other in three different directions, the Bravo 1 was exactly 3 mph faster on GPS than the labbed Hydromotive. Actually, the Bravo 1 was hitting the rev limiter at 5500 rpm, so there may be even more speed there. I wanted to get to 80.0 and got 81.7. Thanks Brett!
Theirs only a few good prop shops around. All my local guys can make them look pretty but for speed I go the BBLADES and his crew. It can be a trial and error type thing but they have pretty much done it all.
I too have gotten vary good results with a BBlades modified 28p B1 pushing my little Superboat. No other 4 blade prop has been able to touch this prop.
I sent a 27p M+ out yesterday to Brett to work his magic. I'm quite confident that we will have similar success with the 3 blade.
Hey Brett,
You'll have my prop on Friday; when should I expect to get it back? No big rush, just asking what the turnaround is these days.
Hey Brett,
Patrick
Patrick
You guys make this late night work all worth while. I mean that.
I hope Dennis is watching. I miss the guy, he was quite the Dandy!
Pat, it's here.
Pat, it's here.
[email protected]
[email protected]
Sounds good.
Wheather and water temps combined with humidity levels are a constant influence. These issues can be a propeller tuners nightmare.
Brett
Brett
[email protected]
[email protected]
BRETTS THE BESTIS OUT THERE
, I hope to be back on the water this spring so we can test the props that we were going to test before all my chit was stolen
. I am sure DENNIS IS WATCHING WITH A SMILE
. art
. art
