Could not launch boat! Shallow water and Rocks! >
Old 09-03-2007 | 09:08 PM
jeff32's Avatar
Default Could not launch boat! Shallow water and Rocks!
Long story short: I went at a usually nice boat launch ramp today, in Varenne, on the Fleuve St-laurent or St-Laurent river. This is where the cargo goes down to the great lakes. Started to back off and felt it would not go in water any further. Boat would not float either. So I tried 2 other times just beside, never worked. I was told to go somewhere else close (Contrecoeur) same story. So I headed to the richelieu river after 3 hours drive, ( an it usually is only 15 minutes from home) finally got it wet!
The Sorel marina where is usually held the poker run was closed. No one could either get in, or out of the marina...
But my trailer suffered a little bit from the first launch ramp! see pictures...
Attached Thumbnails Could not launch boat! Shallow water and Rocks!-3-sept-07-ride-bateau-richelieu-chambly-001.jpg   Could not launch boat! Shallow water and Rocks!-3-sept-07-ride-bateau-richelieu-chambly-002.jpg
jeff32 is offline
Old 09-03-2007 | 09:13 PM
t500hps's Avatar
21 and 42 footers
DUDE!! You have 2 feet of hull hanging off the bunks.....get those bunks extended ASAP!!!
t500hps is offline
Old 09-03-2007 | 09:18 PM
jeff32's Avatar
that is when I was not completly on trailer trying to back up again...
jeff32 is offline
Old 09-03-2007 | 09:19 PM
bluellama's Avatar
Jeff, where has all the water gone ????
The 1000 Islands has dropped almost a foot since the Poker Run, it's at late October, early November levels right now.
bluellama is offline
Old 09-03-2007 | 09:56 PM
pshannon's Avatar
Looks like you stuffed to outdrives a little too.
pshannon is offline
Old 09-03-2007 | 10:01 PM
jeff32's Avatar
yeah, they touched but very little. it is when I wanted to lower them I noticed they touched...
jeff32 is offline
Old 09-03-2007 | 10:02 PM
The big daddy of them all, Lake Superior, is at the lowest level since they have been recording them. It's water temperature, known for being frigid and never giving up its dead, is at all time highs. Not a good situation on any of the Great Lakes.
jafo is offline
Old 09-03-2007 | 10:07 PM
jeff32's Avatar
too bad... I thought the lakes were normal and they had just shut the valves for the st-laurence...
jeff32 is offline
Old 09-03-2007 | 10:20 PM
GO4BROKE's Avatar
Lake Ontario is at the lowest level I have seen. I have about 20-22 feet more shoreline than I do in the spring. The first 20+' of my dock is on dry land. I may have to stop using my boat for the season soon ( launching and retrieving is getting harder) due to water levels, not weather.
[img][/img]
GO4BROKE is offline
BAJA WILL
10-24-2007 05:13 AM
bambigular
6
09-11-2007 05:08 PM
dualprop
09-11-2006 02:34 PM
CrazyCat57
0
03-23-2006 09:01 AM
Audiofn
03-13-2006 09:04 PM
