Odd issue with 454 mag
Ok guys,
I 'm running down the lake and I can smell oil burning. I stop to see if I can see a leak or something. When I lift the hatch smoke rolls out. After all is cleared I notice this smoke is coming from the two hoses that come from the valve covers to the Flame arrester. What gives? it has perfect oil pressure, water temp is fine. Is there a chance that the oil is getting too hot and burning. I don't have an oil temp gauge, or an oil cooler. could there be any other reason for this? If I run easy it won't hardly smoke at all, but if I go for a brisk cruise or WTFO it comes out pretty bad. Thanks in advance if anyone can help.
Anthony
Anthony
Time to check engine health - compression test and/or leakdown test.
Too hot of oil shouldn't cause the smoke, however it can lead to increased engine wear which can then lead issues like this.
The 454 Mag engine's did come with small oil cooler. You may not see it, but follow water inlet hose and you should see it. If you do not have one, look into getting one. Combo power steering/oil cooler is typically used by Merc.
When I bought my boat one engine was missing the windage tray that mounts to the main caps. It made a horrible burnt engine oil smell due to oil splashing excessively on the pistons. It would also cavitate the oil pump at WOT due to blown around oil which could be witnessed by the pressure gage dropping.
If your oil pressure remains solid and your oil level is not too high causing splashing, then I would consider installing a PCV valve. That fixed my windage tray burnt oil problem until I could get in there and install one.
BT
BT
Ive thought of all three things. First it does not have an oil cooler. the boat originally had a 300hp 454. The engine had less than 5 hours on it when I took possesion. I was maticulus with it's break in and oil changes i changed it every 5 hours until I had put 15 on it. I then swithed to Mobil 1 15-50 full synthetic. I check my oil everytime I go out and I haven't noticed any loss of oil. I know that I need to preform a compression/leak down on the engine, But I feel with only 60 hours on it that I SHOUDN'T find any problems. Yes I had planned to put PCV valves on it to see if that would help. any other Ideas out there would be great.
You need an oil cooler and an oil temp gauge. I bet your oil temp is over 300 degrees without one. That will cause some smoke out the breathers. The stock 454 or 502 Magnum cooler is marginal if you like to run hard, I'd use one the size of the HP 500. Buying one used is a crapshoot. You never know if someone blew up their engine and left little bits of shrapnel inside.
You wouldn't notice that unless it was real bad. I upgraded my cooler and have stock oil/ ps cooler I'll sell you if you want it. Promise no junk in it.
